Turbo LSX 2011 Escalade EXT build
#113
#114
Well I pulled this off his faq page on his website.
Quote
Can I use windshield washer fluid?
If you can ascertain the chemical composition of the windshield washer fluid where by it doesn’t have any soap or chemical that would be detrimental to the operation of the vehicle, yes. Examples are winter formulas that use 50-100% concentrations of methanol.
End Quote
So I would say your statement in not true.
Quote
End Quote
#115
Quote
End Quote
Quote
End Quote
been down this route 7 yrs ago
#118
I can't see any meth kit pump not being intended for use with water considering that an approximately 50/50 mix is optimal for knock suppression. At 100% you are using the meth to supplement an inadequate primary fuel system.
Good to see another local build on here!
#119
not all meth kits and pumps are created equal
so to say its a bandaid is far from the truth, some of the fastest cars in the world run on pure meth for a reason. Spraying pure meth is along the lines of that route
its basically having a dual fuel setup
#120
Exactly they aren't! Most pumps cant run 100% Meth. Julio's pumps can. But to say you can not run 50/50 mix is rubbish! Water and Meth is much easier on the pumps then a 100% mix.
