Turbo lq9
Old Jan 15, 2019 | 02:44 PM
99silveradoman's Avatar
Default Turbo lq9
So I've had the truck a little over 3 years now as a daily back and forth to work. Couple months back my 6 year old decided we needed a race truck and how could i say no. So we pulled the 4.8 out of it with close to 300k on it and set it aside to do a 6.0 swap. We started with a lq9 out of a 03 Escalade threw a 228r cam I got from a buddy ls7 lifters ls9 gaskets some studs and the valvetrain goods. It was fun for a street truck but now I have somehow acquired a s475 so the question is stick with the lq9?
Old Jan 15, 2019 | 02:53 PM
Old Jan 15, 2019 | 08:52 PM
ZO6Ted's Avatar
Depends on lbs boost. Not ideal for high boost at all but it could work on street boost just fine.
Old Jan 16, 2019 | 08:31 AM
I was thinking around 13lbs I have a 44mm tial and a 50mm b.o.v and was thinking about a 5.3 or a lq4 for better compression with the turbo?
Old Jan 16, 2019 | 08:56 AM
arthursc2's Avatar
317 heads? Hit that bitch. Keep it intercooled, run e85 if you have it and make 700. Only thing stopping you is fuel.
Old Jan 16, 2019 | 09:42 AM
yeah 317 heads trunion kit and btr .660s need to gap the rings as well. Fuel wise dual 450s in tank with sep 1500cc injectors
Old Jan 16, 2019 | 10:11 AM
ZO6Ted's Avatar
Agreed E85 or meth or both but I wouldn't change the sb because of 10.0 compression. Should run hard and have some low end too.
Oh also talk to someone like Rob about cam specs. You could bleed off some compression if you need to.
Old Jan 16, 2019 | 11:00 AM
Yeah e85 is the plan theres quite a few places around me that sell it and the injectors are for e85 as well. Havent really thought about meth atm
Old Jan 16, 2019 | 11:08 AM
arthursc2's Avatar
I would pick e85 over meth for reliability, ease of use and cost. IMO
Old Jan 16, 2019 | 11:49 AM
03sierraslt's Avatar
My 370 is 10-1 and it works fine. 93 and meth now, soon to be E85 and meth.
