Turbo kit final exhaust, what do you run???
Old Oct 31, 2014 | 01:50 PM
TrickTurbo's Avatar
Truck Sponsor
Default Turbo kit final exhaust, what do you run???
Looking for some info here.
For all single turbo (gasoline) truck owners.
What type and size exhaust do you run with your turbo kit.?
3, 3.5, 4.0,?
Do you run it all the way back or dump at the axle.?
Stuff like that any info is appreciated.
Rick
Old Oct 31, 2014 | 02:16 PM
LS1TRUCKGUY's Avatar
3" dp and 3" to a 30" magnaflow exiting in front of the rear tire. I plan on upgrading to 4" in the near future.
Old Oct 31, 2014 | 02:37 PM
blownescalade62's Avatar
Mine will be 4" Flow- Pro Diesel out side of truck.
Old Oct 31, 2014 | 02:52 PM
tim wellington's Avatar
Default 4 in
from your 3 dp. 3 to 4in conveter 4in all the way 6 in muffler then behind right rear tire .ordered mine for 03 duramax extended cab .
Old Oct 31, 2014 | 02:55 PM
GXPJAY's Avatar
3" cutout before Cat, after cat I have a 3" Magnaflow Cat Back to stock location behind tire.
Old Oct 31, 2014 | 02:56 PM
GMCtrk's Avatar
Full 4" exhaust from the turbine to the factory exit location behind the passenger tire, with the 30" magnaflow diesel muffler. Underside of the bed had to be notched to fit the 4" pipe in between the bed and axle with the rear flip kit.
Old Oct 31, 2014 | 03:07 PM
Gadgetized's Avatar
4" DP to 4" cutout/ to dual 3" inlet muffler to dual 3" pipes out the back.
Old Oct 31, 2014 | 05:27 PM
GRRR65GTO's Avatar
3" dp with 3" pipe to a diamond eye duramax cat back system
Old Oct 31, 2014 | 05:58 PM
RS/SS 4.8's Avatar
10 Second Truck Club
A 3" dp to 3" 22" long magnaflow out the stock location.
Old Oct 31, 2014 | 06:15 PM
Three6GMC's Avatar
I run a 5 inch downpipe all the way back to a 5 inch cutout and after the cutout it necks down to 3.5 and connects to my factory 6.2 exhaust
