Turbo kit final exhaust, what do you run???
#28
Injector options would be awesome... That would be a big plus for you Rick.. I know a guy like me that has built a few turbo trucks, cars etc.. i would love to know i can get everything i needed from one place in a nice package deal. Im alot about easy these days.. lol
#29
4" turbo back with side exit through the rear passenger side bed before the tire. It is hard to do side exit with a 4" exhaust if you're lowered. 3" will hit speed bumps let alone 4. The side bed exit also has its draw backs because I had to route between the frame and the leaf. If I hit a big bump, it'll squeeze the pipe lol. I have a 5" tip on it only because I had it sitting around.
It is also really hard to have full exhaust if you're lowered. my 6" flip kit leaves all of 2" between the bump stop and the bottom of the bed. I'd hate to run it under the axel too.
Either way, I like it. It is super duper quiet. I run open wastegate dumps so it sounds good when it needs too.
Muffler - Dynomax Ultra Flo Welded Mufflers 17557
If you're serious about building a kit, look at 2 bolt 1/2" flange connections. something like this bastard http://vibrantperformance.com/catalo...oducts_id=1254
You wouldn't need stainless, mild would be fine. If you're going to make a run you can get a laser shop to cut these pretty cheap. Import 4" exhaust (greddy for instance) always use 2 bolt flanges. The work great.
v-bands, sleeve clamps and u-bolts are all crappy. V-bands you can never position right. Sleeve clamps always leak and loosen. u-bolts sometimes leak, but you can never take the exhaust apart after you pinch the slip connection.
#30
Love the exhaust boostedsl2!! I'm going to get that muffler! Will be running a cutout for when its time turn heads. I've been looking for a non restrictive muffler that's quiet. Looks like I finally found one.
