Turbo heat management ideas
Old 05-08-2017, 10:40 AM
  #21
Boost-freak's Avatar
Originally Posted by NoorJ
bringin this back from the dead!
I've had my build finished for almost a year with no problems (save a 4l80e tailshaft housing) and it never got hotter than 210*F except when running A/C. I recently took my turbo RCSB down to tail of the dragon (bike and stuff in back) and she got real toasty in the mountains on the drive home up to about 230-235*F on some of the real long uphill straights. This was converter locked up cruising at about 70 the whole way, manifold pressure around 8inhg vacuum
Some specs on the setup are;
bone stock 5.3L oil pan to valve covers
on3 7875
4l80e with 2800 circle d stall
flex fuel conversion
stock 28" radiator (i know i know not good)
ls1 efans
tru cool 40k trans cooler
huge ebay 4" core intercooler
fully heat wrapped hot side and turbo blanket
I'm thinking I need to just bite the bullet and get a 34" rad and the big truck efans. The truck has about 150k on it, so I was planning on doing a water pump and a 180*F thermostat as well when I put in my LS6 cam. Just wondering if anyone else if running into problems like this, maybe when towing or in real hot climates
180f thermostat
34 rad
70-30 mix
Old 05-08-2017, 11:43 AM
  #22
2ToNe04's Avatar
on3 7875
ls1 efans
Im in the same boat. What big truck fans are you talking about, id be interested. As of right now, im planning to do a 160 Tstat, ill report back with my results. If the t-stat doesnt remediate the issues, i might be swapping over to a bigger rad as well.
Old 05-08-2017, 02:41 PM
  #23
vettelovralexand's Avatar
A thermostat isn't going to change jack in the temperature range everyone is talking about. You need to get the heat out of the engine and that requires heat exchangers or to better utilize the ones you have. You can increase the effectiveness by increasing coolant flow, by increasing airflow over them, improving the working fluids' heat capacity, or by increasing the heat transfer coefficients (think water wetter). A thermostat that is full open by 100 F vs one full open at 200 F won't make a bit of difference at 210 F.
Most people don't consider how much heat their coolant has to reject to the atmosphere when you start increasing the power. Most get away with it because they don't use it for more than a few seconds at a time, but even a simple timing advance adds more power but also increases the amount of heat going into the coolant due to the change in the in cylinder residence time. (it moves the energy from exhaust heat rejection to coolant). With a turbo, now the energy that used to go out the exhaust becomes turbine power and is used for compressing air.
This is a little longwinded, but imagine your truck's most powerful engine option 6.0 or 6.2 running full tilt on a 125 degree day up the longest grade in the country. You can bet that your stock cooling system will handle that without overheating, but any well engineered system won't allow for much more.
Old 05-09-2017, 07:13 AM
  #24
NoorJ's Avatar
The 07-10 truck had "big" electrical fans that push much more air than my tiny LS1 efans. I considered a 160 stat but I drive this thing thru michigan winters so I'm hesitant to put too low of a thermostat in and never get the oil hot enough to burn off all the fuel/**** in it. I figure 180 is a good balance
Yeah I understand the concepts of cooling systems, I'm an engineer in the automotive sector. What you're referring to is a system in equilibrium, where I'm taking about a system that starts in equilibrium (at the bottom of a hill) and sees a large change in heat rejection demand. It can't handle that demand so temperature starts increasing until equilibrium is reached (right now for me that's probably around 235*F) A cooler thermostat gives your a larger thermal mass to heat up, therefore more time until that equilibrium is reached. Because I don't have an issue other than these big hills, I think a thermostat will *help* but not solve the issue.
Old 05-09-2017, 07:31 AM
  #25
11 Second Club
Mean Green z28's Avatar
on3 7875
ls1 efans
How do you like that stall on it? I have On3 7875 and 4L80E too but it's really sluggish on take off with the 3.42 gears in the back. A 3200 stall fixed some of it but I didn't like to have to Rev it up that high to get any kind of performance around town; stock went back in. Thinking of going with 4.11 gears.
Old 05-09-2017, 09:11 AM
  #26
NoorJ's Avatar
It's the perfect combo for me, I don't drive it too crazy just a fun daily driver that I can haul stuff with and scare people on the highway. It is a little sluggish in first, but I just spin 1 tire anyways so until I get the the tru-trac installed it doesn't really bother me. I think the 4.11's would be a good solution for you though, but would definitely be better with a stall
Zizzle
10-19-2017 08:44 PM
ullose272
08-05-2016 02:05 PM
thunder550
10-08-2015 04:53 PM
WICK3DxGATA
07-21-2015 06:59 PM
Quick Reply: Turbo heat management ideas
