Turbo guys, does this seem normal?
One thing too look at as far as running meth is what size injectors are you running? Some people say meth injection is just a band-aid fix for not having enough injectors. If you are not having problems with high iat's or detonation (KR) then not running meth really should not be a problem. Bein that you are down in TX I would suguest it just cause of the heat down there. Also nice thing with running meth is that you can add more timing. I recently got meth injection on my truck that is running 11psi and I notice a tremendous difference. I am still learning about all this stuff. But I would suguest sometime in the near future getting a meth injection setup.
Methanol injection is a great thing. It does all that is advertised and can even buy headroom in your fuel system. I still feel nervous relying on it (as I do anything that is not stock). Once you have tried/tuned for it you won't want to go back.
I think you can manage 10-12 psi without the methanol by limiting timing. By limiting timing you are limiting power and you may make similar numbers at 8 psi with 18* as you would at 12 psi with 10*. There is an octane threshold that will ultimately limit your power.
I really appreciate everones input...very helpful.
If you stick with the 60s and limit your boost accordingly, the single walbro will be plenty and you won't need meth. Are you running a FMIC? I assume so given your boost level already.
I'd really recommend a meth kit for those days when you want to turn up the boost. You might not have enough pump to run 12psi on a 6.0L without meth -- you'll hit 550 easily.
Meth will chemically intercool your charge plus add fuel and octane. It's like magic... If you have a boost controller anyway, you can do a low boost dd setting and leave the meth off, then flip a switch, turn the meth on and go high boost for the honda at the light
What is your A/F showing when running straight meth. I just got my meth kit and been playin around with the mixtures. And the 42's are the car injectors, right?
I think 44s are Marine 8.1 and 42s are truck 8.1. I thought the cars were just 28s or something but I dont know.
. I was just curious cause I got the car injectors in my truck and did not know what hp they where good too
