Turbo guys, does this seem normal?
Old Aug 31, 2008 | 01:07 AM
ZO6Ted's Avatar
Originally Posted by 1BADAZZSS
One thing too look at as far as running meth is what size injectors are you running? Some people say meth injection is just a band-aid fix for not having enough injectors. If you are not having problems with high iat's or detonation (KR) then not running meth really should not be a problem. Bein that you are down in TX I would suguest it just cause of the heat down there. Also nice thing with running meth is that you can add more timing. I recently got meth injection on my truck that is running 11psi and I notice a tremendous difference. I am still learning about all this stuff. But I would suguest sometime in the near future getting a meth injection setup.
I'm running 60's with a single in tank Walbro.
Originally Posted by Stoichiometric
Methanol injection is a great thing. It does all that is advertised and can even buy headroom in your fuel system. I still feel nervous relying on it (as I do anything that is not stock). Once you have tried/tuned for it you won't want to go back.
I think you can manage 10-12 psi without the methanol by limiting timing. By limiting timing you are limiting power and you may make similar numbers at 8 psi with 18* as you would at 12 psi with 10*. There is an octane threshold that will ultimately limit your power.
Maybe I will at least talk to my builder about it. I just hate to complicate the truck with too many add-ons...however I do want to be safe.
I really appreciate everones input...very helpful.
Old Aug 31, 2008 | 01:21 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
If you stick with the 60s and limit your boost accordingly, the single walbro will be plenty and you won't need meth. Are you running a FMIC? I assume so given your boost level already.
I'd really recommend a meth kit for those days when you want to turn up the boost. You might not have enough pump to run 12psi on a 6.0L without meth -- you'll hit 550 easily.
Meth will chemically intercool your charge plus add fuel and octane. It's like magic... If you have a boost controller anyway, you can do a low boost dd setting and leave the meth off, then flip a switch, turn the meth on and go high boost for the honda at the light
Old Aug 31, 2008 | 01:28 AM
ZO6Ted's Avatar
Yes on the FMIC. That actually sounds like a great idea...maybe 10/14 lbs then with a boost controller and Meth?
Old Aug 31, 2008 | 10:02 AM
WJ MARK's Avatar
I love my meth, I am maxed on my 42's @ 10-12 psi and the meth really helps. I can really notice the difference in power and A/F running strait meth. I don't mix it. screw the water!
Old Aug 31, 2008 | 01:55 PM
1BADAZZSS's Avatar
What is your A/F showing when running straight meth. I just got my meth kit and been playin around with the mixtures. And the 42's are the car injectors, right?
Old Aug 31, 2008 | 02:17 PM
1989k1500's Avatar
8.1 injectors
Old Aug 31, 2008 | 02:52 PM
I AM A MOTHERF*CKER
Don't even waste your time with adding water Just go straight 100% meth.
Old Aug 31, 2008 | 05:46 PM
1BADAZZSS's Avatar
Originally Posted by 1989k1500
8.1 injectors
Ok I always get them mixed up and always thinkin the 8.1l where #44's and the 42's where the car injectors. I was just curious cause I got the car injectors in my truck and did not know what hp they where good too
Old Aug 31, 2008 | 05:52 PM
1989k1500's Avatar
I think 44s are Marine 8.1 and 42s are truck 8.1. I thought the cars were just 28s or something but I dont know.
Old Aug 31, 2008 | 06:35 PM
kbracing96's Avatar
The 8.1 marine injectors and are rated at 43.something,
8.1 truck injectors are 31lbs/hr I belive.
