Turbo guru's 6.0 recommendations
Old Jan 15, 2006 | 08:34 PM
  #31
fullthrottledan's Avatar
Originally Posted by hellbents10
You mean by 88 you mean exducer sizer and not inducer which is what these gays are speaking of.
Also at 15 psi or better the 40-67 is not the best choice. You would be better off with a 42-72 (or76 if you would like to move a little more air) Or a S72, which takes a little longer to spool but will ultimatly make more power because of the better flwing wheel.
yeah, 88mm exducer, 64.7 inducer, 77mm turbine
Old Jan 15, 2006 | 10:20 PM
  #32
TurboGibbs's Avatar
Originally Posted by zippy
Thanks Zippy! I just pm'd the guy to buy it and waiting to hear back. It may be a little on the large side but just about anything would make me happy. I'll have plenty of room to grow.
Old Jan 16, 2006 | 11:07 AM
  #33
hellbents10's Avatar
LS1Tech Sponsor
Definatly not on the large side for a 6.0l, Zippy is on the right track with that turbo, it will work very well on a mild 6.0l. Infact that would be great for a entry level up to 700rwhp or so turbo on a 6.0l.
Old Jan 16, 2006 | 12:13 PM
  #34
TurboGibbs's Avatar
I just bought it. It is supposed to be capable of 1200hp but on the inefficient system I will have I'd be more than happy with 700@ the flywheel. 600+ rwhp on a real world DD is enough i think
Now I just need recommendations on a boost controler, wastegate, and blowoff valve.
Old Jan 16, 2006 | 01:04 PM
  #35
zippy's Avatar
congrats on the big air mover. that ought to get you up to a boost level to make the low compression worth it.
Old Jan 16, 2006 | 01:16 PM
  #36
TurboGibbs's Avatar
Yeah. The more I thought about it the radix just wasn't what I needed. It is a great system for up to just a little over stock . Other than that it just isn't the best way to go. The radix does perfect for what it was designed to do though.
It's gonna be fun
Old Jan 16, 2006 | 01:22 PM
  #37
LS1Tech Sponsor
Look into a Turbosmart 48mm gate and a turbosamrt blow off.
Old Jan 16, 2006 | 03:05 PM
  #38
turbo595's Avatar
Which exhaust housing do you have?
Old Jan 16, 2006 | 04:02 PM
  #39
LS1Tech Sponsor
I would guess its a .81 T4.
Old Jan 16, 2006 | 04:59 PM
  #40
very smart! its a good turbo for now. I want to really get serious with it soon!
