turbo feed lines
Old Sep 18, 2008 | 02:04 PM
53RUSSELL's Avatar
Default turbo feed lines
Well have -3an pre-made oil feed line and they are leaking around the swivel end of the fitting. What are you guys running?
Old Sep 18, 2008 | 02:33 PM
kbracing96's Avatar
I have -4 pushlock hose and ends on my truck
Old Sep 18, 2008 | 02:47 PM
7845's Avatar
Banned
-4 russell
Old Sep 18, 2008 | 04:06 PM
WJ MARK's Avatar
-3 line
no leaky
Old Sep 18, 2008 | 05:05 PM
TrickTurbo's Avatar
Truck Sponsor
If the line is tight and still leaks, try removing it, clean it good with break clean etc. And use a little red loctite. And then snugR back up tight, wait about an hour and see if you still have a leak. AN fittings are good for sealing, but ANY nick in the sealing area can cause a slight leak.
Old Sep 18, 2008 | 07:44 PM
53RUSSELL's Avatar
Rick have one of you set lines and broke one of the fitting from over tighten them and I also tried the tread sealer that you said when we talked on the phone the other day. Do you make these lines in house??
I got another set from here local and still have same problems.
This truck just likes oil right now and spent lots of time on this problem.
Old Sep 18, 2008 | 07:47 PM
nonnieselman's Avatar
I just used a -4 nitrous line..
Old Sep 18, 2008 | 09:21 PM
Bill Reid's Avatar
... running a pre-made oil line... Earls (Summit) part EAR-63010172ERL... it has straight female ends. I adapted that to a 90 on top of the turbo. See siggy Zero issues.
Bill
Old Sep 18, 2008 | 11:34 PM
53RUSSELL's Avatar
Bill
I'm not leaking at top it's one buy the pan leaking??
Old Sep 19, 2008 | 07:56 AM
TrickTurbo's Avatar
Truck Sponsor
The lines are premade, -3 female ends.
Ok you switched lines and it still leaks? This is the part right above the oil filter.? Did you tap it or get the billet adaptor.
Sounds like we have few choices right now.
1) The fitting with pipe threads is damaged in some way or not tight on the pipe thread.
2) the stock housing if used maybe cracked.
3) the bunts are slightly too long to allow full tighting on the male fitting, not likely since it seems you change hoses.
I would take it all apart clean it good and inspect all fitting, adaptors, gaskets in that area.
Call me if have any questions.
Rick
GXPJAY
Feb 13, 2022 08:15 AM
chopperloco
Jul 10, 2016 10:45 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mzay
Jul 6, 2015 11:03 PM
