Turbo Dyno numbers - Ignition/ SCR/ Questions!
Formerly ScreamingL
Tr6 is fine for low power with low compression...hell while trouble shooting i ran tr6 in my 427 for 7 psi and low rpms just cause parts srores dont stock br7s
.028 should be used for around 18psi (give or take)
.024 for above that
But each setup is different...example 7 psi my 427 is rwhp range of 900 at 7500
Just keep eye on logs...if map reading looks like a sae blade you have blow out
.024 for above that
.024 for above that
.024 for above that
Originally Posted by George C....
I have wires for a lt1 on my truck since my coils are relocated
Formerly ScreamingL
Probably wont like it honestly unless compression was so low
A psi number doesnt always mean the same as next guy..15psi from my twins is 1300 rwhp range
15 psi from a on3 70 is 600 range
Tr6 at 15 probably wont take much timing without putting heat mark to far down strap but only 1 way to find out
01SilveradoJakee
02-12-2016 08:08 PM
