Turbo Dyno numbers - Ignition/ SCR/ Questions!
Old Mar 25, 2016 | 08:16 AM
George C....'s Avatar
Formerly ScreamingL
Tr6 is fine for low power with low compression...hell while trouble shooting i ran tr6 in my 427 for 7 psi and low rpms just cause parts srores dont stock br7s
.028 should be used for around 18psi (give or take)
.024 for above that
But each setup is different...example 7 psi my 427 is rwhp range of 900 at 7500
Just keep eye on logs...if map reading looks like a sae blade you have blow out
Old Mar 26, 2016 | 10:27 AM
musclecity85's Avatar
.024 for above that
i guess what do you consider low power? im doing an lsa swap on my 08 silverado and im looking to make about 12-14 lbs of boost. Im not sure what that would relate to hp wise. but i would told to run a br7 plug in one instance and told a br6 would work in another. which way do you guys think i should go?
Old Mar 26, 2016 | 10:29 AM
Formerly ScreamingL
With a heat pump for a power adder id use br7ef
Old Mar 26, 2016 | 11:42 AM
thanks
Old Mar 27, 2016 | 02:17 PM
Jetn3's Avatar
Hey George, what plug wire do you use?
Old Mar 27, 2016 | 04:39 PM
Formerly ScreamingL
I have wires for a lt1 on my truck since my coils are relocated
Old Mar 27, 2016 | 06:14 PM
lxcoupe's Avatar
George any thoughts on 12-15psi E85 setups possibly liking a 6 heat range plug more than a 7 compared to pump gas/meth setups? I'm sure everyone is sick of the "what plug" questions but I was just curious if hotter plugs and e85 are related.
Old Mar 27, 2016 | 07:26 PM
Formerly ScreamingL
Probably wont like it honestly unless compression was so low
A psi number doesnt always mean the same as next guy..15psi from my twins is 1300 rwhp range
15 psi from a on3 70 is 600 range
Tr6 at 15 probably wont take much timing without putting heat mark to far down strap but only 1 way to find out
Slow91z
20
Feb 15, 2016 03:51 PM
chopperloco
Feb 14, 2016 03:39 PM
Garrett Scott
Feb 14, 2016 03:22 PM
01SilveradoJakee
Feb 12, 2016 08:08 PM
terravast4
Feb 12, 2016 09:58 AM
