Turbo drain question
Old Jun 29, 2024 | 05:15 PM
Wolfy1969's Avatar
Default Turbo drain question
I have a 2000 Silverado with full accessories and a/c in stock location. Where are you guys putting the turbo drain on these?
thanks in advance. By the way. Turbo is going on the pass side front. Normal location.
Old Jun 30, 2024 | 12:29 AM
Fullpower's Avatar
1/2" NPT tapped into FRONT of oil pan, between crank pulley and A/C idler.
It's pretty tight, but I drilled and tapped it in place.
Old Jul 11, 2024 | 09:30 AM
twigy's Avatar
Passenger side between the 1st and 2nd oil pan bolt from the front.
Old Sep 6, 2024 | 06:46 PM
Fullpower's Avatar
Checking back on this thread.
As pictured above, drain return into fron passenger side of oil pan, so far, NOT able to install AC drive belt.
Tried a few "adjustments" to the 45 degree elbow, not happening.
Maybe a slightly longer oversize belt, say 5/8" longer ? Not SUure.
Followed the pictorial instructions in the Huron Speed download pretty carefully. Maybe my ANGLE was slightly off, don't know.
99LopinRado
Sep 9, 2011 12:10 PM
blu01slver
Feb 20, 2007 12:36 PM
seeyaa
Oct 20, 2005 11:55 PM
