Turbo drain
Old Nov 20, 2016 | 05:47 PM
justuc's Avatar
Default Turbo drain
Getting ready to drill a hole in my pan for turbo drain. What size are most of y'all running and are y'all welding them or regular bulkhead fitting?
Old Nov 20, 2016 | 06:20 PM
JordanH's Avatar
Restricted
Most smaller/medium turbos will be fine with 3/8-1/2npt, for larger frame turbos and bigger drain lines I'll use 3/4"npt and a 12an line... and it doesn't hurt anything to run a larger drain anyways! So my advice is run a 3/4"npt and 12an line!
Old Nov 22, 2016 | 09:04 PM
TrendSetter's Avatar
i use 1/2npt or weld on a -10an. never any problems but maybe im lucky.
Old Nov 22, 2016 | 10:34 PM
RS/SS 4.8's Avatar
10 Second Truck Club
-10AN here and no problems on T76
Old Nov 24, 2016 | 11:02 PM
FetzerValve's Avatar
-10 AN with 1/2" npt fitting on front of oil pan below the crank pulley. I drilled and tapped the oil pan and ran the fitting in. Been like that for a couple thousand miles and hasn't leaked at all.
Old Nov 24, 2016 | 11:37 PM
Atomic's Avatar
I have a gauge for that
I used 1/2" npt and 5/8" nice hose.
Old Nov 25, 2016 | 02:13 PM
TrickTurbo's Avatar
Truck Sponsor
3/8npt X 5/8 hose barb is sent out with all our kits.
Except large frame BB T6 builds. They get 12.
Old Nov 26, 2016 | 09:29 PM
Gadgetized's Avatar
I had to go up to a 12AN. Just make sure to drill above the oil level and try to route the line as straight as possible.
