turbo to downpipe seal
Old May 5, 2016 | 10:04 PM
mhorn0817's Avatar
Default turbo to downpipe seal
I just put a new v band clamp on my turbo to downpipe and i can feel some air coming out of it. Is any air coming out normal or should there be no air. Im not sure if it sid that before or not. Is there a seal or gasket i can put between the two to help seal better?
Old May 6, 2016 | 12:55 AM
Blown06's Avatar
8 Second Truck Club
It can be normal if it is just regular cheap flanges that don't have registers.
This is the sole reason I only buy racepart solutions vbands. they have locating registers that overlap and keep everything straight and square. They are also machined for an oring for cold side piping.
Old May 6, 2016 | 06:20 AM
mhorn0817's Avatar
It's a vibrant brand so I guess it's a cheapo. It lined up the two flanges good and snug but just getting a little air coming out of it
Old May 6, 2016 | 06:32 AM
TrickTurbo's Avatar
Truck Sponsor
If still doing after heated up.
Just apply a small amount of rtv to the mated surfaces.
Reclamp. Wait then try again.
Old May 6, 2016 | 08:22 AM
Atomic's Avatar
I have a gauge for that
You will want to use the male/female vbands, they have a little groove in them to seal better. You dont want any leaks, it will throw off your wideband sensor readings.
Old May 6, 2016 | 09:20 AM
mhorn0817's Avatar
Its vibrant 1491clamp if you want to look it up. It does have a groove but maybe youre talking about something else im not sure of.
Would kind of rtv could i use?
Old May 6, 2016 | 10:05 AM
TrickTurbo's Avatar
Truck Sponsor
Hi temp rtv. Sensor safe.
Old May 6, 2016 | 07:52 PM
GRRR65GTO's Avatar
This happens to me too and I've already put on a new racepart solutions clamp
Old May 8, 2016 | 03:31 PM
mhorn0817's Avatar
Ill try rtv gasket maker. I picked up a round 3" gasket that im gonna cut the ears off and see if that helps as well
Lane_Hesser
May 6, 2016 12:12 AM
Lane_Hesser
May 5, 2016 10:19 AM
zraffz
May 1, 2016 08:44 PM
tgui
May 1, 2016 07:07 PM
