turbo comparison
Old Aug 5, 2015 | 10:19 AM
tim wellington's Avatar
Default thoughts on dyno numbers
good to look at but can cant always determine speed or e.t .examples if a car or truck make 1200 at 5800 to 6100 then falls to 975 6200 to 6800. another vehicle makes 1075 from 5800 to 6800 in the same kind of vehicle it possible the 1075 will run quicker.also more power in wrong set up suspension can lead to slower e.t. with high mph (mph doesnt win races) just my 2 cents. but thank to all on turbo opinion .I LOVE THIS SITE
Old Aug 5, 2015 | 11:50 AM
George C....'s Avatar
Formerly ScreamingL
3400lbs here at 164 made 1053 on a dynojet.....just saying
Old Aug 5, 2015 | 12:14 PM
kbracing96's Avatar
Jarrett hasn't made a clean pass on a good track with the new motor and turbo yet at full boost. When he does, It will probably be in the 7's...
Old Aug 5, 2015 | 12:22 PM
Formerly ScreamingL
Not doubting car....doubting turbo..
Local car is running a s500 and makes 1220 on 23 psi from a 414 on e85
Old Aug 5, 2015 | 05:12 PM
Jake99's Avatar
He also has the the big heavy 76mm wheel and the 96 exhaust wheel that comes from t6 turbo. The lighter 76/92 he had before would be down 100hp pretty ease. We ran a base s475, cast 75 with 75 exhaust wheel 1.0ar on a ls2 truck, it ran 136mph on 18psi at 4750lbs. We turned it up to 22psi and it gained nothing so thats pretty much were it maxed out at. Probably close to 900rw.
Old Aug 5, 2015 | 05:44 PM
Formerly ScreamingL
dyno'd 700 rwhp trapped 130 and weighed 4700lbs.....that was on a 5.3 at 12.5 psi
point is not all dynos are reading correct, if the combo truly made 1200 rwhp then its going to trap well into the 170s at his weight
now back to the original topic, swapping to a Bw wouldnt gain ya nothing
Old Aug 5, 2015 | 06:52 PM
MechE's Avatar
im sure it would trap well into the 170s... he's at high altitude and he has yet to turn it up..just saying....
Old Aug 5, 2015 | 08:42 PM
TrickTurbo's Avatar
Truck Sponsor
Tim to gain by swapping turbo it will need to be at a higher boost level.
The Borg will have a larger exhaust wheel allowing you to lower BP.
BUT it will not light off like the 76/75.
Also you will need a larger down pipe.
Might as well go to the 46mm gate (future use)
A couple of different cold parts
Larger air filter assembly.
Dynos are nothing more then a tuning tool.
Did the correction help or hurt the curve.
Make a change repeat.
kha4079
Oct 29, 2018 04:38 PM
lxcoupe
Sep 6, 2017 08:24 AM
chvy=power
Sep 8, 2015 11:06 AM
slowswb
Sep 5, 2015 02:27 PM
Bluecollar Hotrods
Sep 1, 2015 07:45 AM
