Turbo charge pipe size question!
Old Nov 14, 2009 | 09:42 AM
ryan_prettyman's Avatar
Banned
Default Turbo charge pipe size question!
The kit that I bought I am relocating the innercooler behind the ss bumper the pipe from the turbo to innercooler is 2" and I will just have to add a little bit more tubing to make it to the innercooler but I am contemplating rebuilding the whole tube out of 2.5" instead it is odd because the pipe going from the innercooler to the throttle body is mostly 2.5" so what size should I get? I could really use you guys expertise!
Old Nov 14, 2009 | 10:40 AM
parish8's Avatar
single digit dreamer
i like to work my way up in pipe size from the turbo to the tb. usualy go 2.5" from the turbo to the intercooler. then 3" from the ic to the maf. then even upsize again if you can and run a 3.5" from the maf to the tb.
if it isn't too much work or expense i think it would be worth it to upgrade to a 2.5". 2" seems pretty small.
Old Nov 14, 2009 | 11:20 AM
Banned
Yeah it does work it's way up right now I believe it does go to 3.5" from 2.5 from the innercooler, so should I ditch the 2"?
Old Nov 14, 2009 | 11:41 AM
kbracing96's Avatar
If your only running about 7psi of boost, you'll never notice the difference. At that level of air flow your not really restricting the flow with small tube size. You start running more boost then is might help, but probable nothing you will ever feel until you go to a bigger motor and higher boost and need the increased area for air flow.
Old Nov 14, 2009 | 12:29 PM
Banned
I think I will go ahead and step to the 2.5" because I have to reconstruct the tube anyhow!
Old Nov 14, 2009 | 05:50 PM
Coban's Avatar
I would say 2.5". However, I think the smaller the volume of the charge pipe, the more responsive it will be!
Old Nov 15, 2009 | 10:08 PM
Banned
Is exhaust leaks normal for turbo kits because I pressurized the exhauste with 10psi shop air and checked everything with soapy water I thing everything is leaking! Is this normal for a turbo kit?
Old Nov 16, 2009 | 04:57 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
i have all 3" aluminum cold side piping
Old Nov 16, 2009 | 05:42 PM
1st_TACO's Avatar
my junk is all 3in also..... but of course i am not ls based.
Old Nov 16, 2009 | 09:09 PM
kbracing96's Avatar
No you don't, you have boxes full of stuff!
