Turbo cam/exhaust
Old Feb 9, 2021 | 04:18 PM
  #21
shakenfake's Avatar
Shlumpt
5 Year Member
Also while we are all here, should I swap heads to my 317s I still have or continue to run the 862s with the turbo? I think I'm at 10.4 compression with my 862s on stock LQ4, **** I hope so that's what I put down when the dude tuned it. I remember reading and working it out it late one night and writing it down never to think about it again but I digress, I have the 317s just sitting in my garage I would just need to swap them out before I put the turbo on, sadly that will increase cost as I will need new gaskets etc.
Old Feb 9, 2021 | 04:33 PM
  #22
shakenfake's Avatar
Shlumpt
5 Year Member
By the way these are stock 862s, I didn't think about adding 2" valves until after I had them done and really didn't want to take them back
Old Feb 10, 2021 | 05:34 AM
  #23
94heritage's Avatar
I would leave the 862s. Makes for better response. You could add a 2” valve and do some chamber work to unshroud the valves if you wanted to but stock 862s have made 800+hp tons of times
Old Feb 10, 2021 | 06:37 AM
  #24
shakenfake's Avatar
Shlumpt
5 Year Member
The only thing I don’t really want to do is run meth. I think I should be okay but I’m not 100%. I may be fine doing it but it would not be my favorite thing right now
Old Feb 17, 2021 | 10:25 AM
  #25
Troy5061's Avatar
11 Second Club
I made a 3" downpipe off my on3 78/75 till just under the truck and used an adapter to make it 4" and ran the Mbrp diesel exhaust out the back. Cam is a texas speed low lift 5.3 boost cam 218/224 .550/.550. Works great in my 6.0 and sounds good! I have a fti 10" 3200 80e converter and with this setup the spool is pretty much instant.
Old Feb 17, 2021 | 10:49 AM
  #26
shakenfake's Avatar
Shlumpt
5 Year Member
Would it be worth it in terms of gains to go from a 3” DP to a 4”?
Sounds like a good setup!
Old Feb 18, 2021 | 10:06 AM
  #27
Troy5061's Avatar
11 Second Club
All depends on how much power you want to make, don't need 4" for 5-600hp but I like the way it sounds better and helps with spool. Plus the cheapy diesel exhausts fit good under my 00 ext cab 1500 and they're all 4" or 5".
Old Feb 18, 2021 | 07:01 PM
  #28
shakenfake's Avatar
Shlumpt
5 Year Member
Yeah I think what I am going to do is just do the 3" back and have a 4" electric cutout just for ***** and gigs
Old Feb 19, 2021 | 05:19 AM
  #29
03sierraslt's Avatar
Just run a 3” cutout, there are a lot more options and they are more reliable. You will still have two 3” pipes for the exhaust to escape.
Old Feb 19, 2021 | 12:30 PM
  #30
shakenfake's Avatar
Shlumpt
5 Year Member
Fair enough, probably save me some coin for other things. I think I have the turbo priced out all I need is to get a fuel pump. Am I going to need to new fuel rails/line or will the stockers work? Still looking for maybe upper 500 lower 600hp
