turbo build info needed (fuel Help)
Old Feb 25, 2013 | 10:03 PM
bluebommer07's Avatar
Default turbo build info needed (fuel Help)
ok im in the process of finally doing a turbo build well luckily i have boosted friends close by are i would be bad off, anyway i went to get fuel pump today and after futher examining i have a returnless fuel system, and from we came up with a walbro 225 wont work, (buddy had first hand experience with that lol) anyway what are some kits/ideal i can do to fix this problem, i could use same setup as his but ill rather not copy his setup unless there no other options. so if anyone has ran into this problem chime in please.
Old Feb 26, 2013 | 01:16 AM
black04's Avatar
Why wouldn't a walbro 255 work? Worked just fine with my returnless system.
Old Feb 26, 2013 | 04:45 AM
blue0453's Avatar
^same here.. ran up to 13psi with meth using that pump. Dont worry about copying. No need to reinvent the wheel. That pump is about as close to a drop in pump as your gonna get.
Old Feb 26, 2013 | 10:29 AM
chevyboy.520's Avatar
If you don't want to convert to return, then a walbro 255 will work, maybe even a 400. I ran the aero motive 340 return less for a while. It over heated on me, then I went a head a did the rest of my fuel system. Dual 400's added a feed line, use the stock feed for my return, get fuel rails and a boost reference regulator.
Old Feb 26, 2013 | 10:32 AM
Oh yeah! A hot wire kit is a good thing to get too!
ZONES89RS
21
Sep 24, 2015 05:58 PM
USMCvet0311
Aug 14, 2015 10:28 PM
rojeho
Jul 12, 2015 06:10 PM
Cowboy17
Jul 9, 2015 06:18 PM
Aboss
Jul 9, 2015 10:28 AM
