turbo build info needed (fuel Help)
ok im in the process of finally doing a turbo build well luckily i have boosted friends close by are i would be bad off, anyway i went to get fuel pump today and after futher examining i have a returnless fuel system, and from we came up with a walbro 225 wont work, (buddy had first hand experience with that lol) anyway what are some kits/ideal i can do to fix this problem, i could use same setup as his but ill rather not copy his setup unless there no other options. so if anyone has ran into this problem chime in please.
If you don't want to convert to return, then a walbro 255 will work, maybe even a 400. I ran the aero motive 340 return less for a while. It over heated on me, then I went a head a did the rest of my fuel system. Dual 400's added a feed line, use the stock feed for my return, get fuel rails and a boost reference regulator.
