Turbo Blazer to be UNTURBO'D!
Old May 26, 2007 | 11:17 AM
Default Turbo Blazer to be UNTURBO'D!
well my turbo is taking a **** on me so its getting sent out for a rebuild
im getting bigger compressor and turbine housings going to a
60-1 compressor housing, with a .83 a/r turbine housing
also i am selling all of my rearmount stuff and i already have a battery relocation kit.
the new set-up will be-
cometic Head gaskets
ARP head studs
1.6 RR's
taurus e-fans
Reinstall my devils own 2stage meth kit.
EIC (extra injectors)
Hptuners 3bar SD
Tial 38mm W.G.
Flipped stock manifolds and 2.5" crossover.
3.5" DP to a full 3.5" exhaust
3" boost pipes
3000stall converter
all billet servos
B&M tranny cooler
Ford 8.8" rearend
possibly a cam and headwork..... goal is 400whp on stock bottom end
Old May 26, 2007 | 11:55 AM
WJ MARK's Avatar
Sounds like you have your work cut out for you. Good luck with the new setup!
Old May 26, 2007 | 12:35 PM
97sicksled's Avatar
x2 BTW did you just put a rollpan on that thing? I think i saw you the other day and your blazer had a new rollpan.
Old May 26, 2007 | 04:29 PM
03sierraslt's Avatar
Sounds like it will be pretty sweet with those plans. I want to see some pics of this..
Old May 26, 2007 | 07:21 PM
if things go as planned im prolly gonna be able to put a built bottom end in the beast bye the end of summer (JE 8.5:1 pistons, Eagle rods, Cryo'd crank, 4-bolt mains, ARP hardware, balanced) and go for 550+whp. might need a T70 w/ .96 a/r for that
some pics of the set-up right now.-
Old May 26, 2007 | 08:38 PM
TrickTurbo's Avatar
Truck Sponsor
Good luck with your new built.
Rick
Old May 27, 2007 | 03:30 AM
cpelton's Avatar
nice oil pump i run one that looks identical. Mocal oil pump: http://www.racerpartswholesale.com/mocal1.htm
Just curious if you've had any problems with yours?
Old May 27, 2007 | 03:55 PM
nope no problems with it so far. put a turbo timer on it though..... i am going to do that as soon as i get some other **** fixed.
Old May 28, 2007 | 12:03 PM
nightrunner's Avatar
Mr. Obvious
what are you doing for fuel? i thought the 4.3L fuel setup was hard to modify without going to a carb-style intake or something
Old Aug 17, 2007 | 11:10 AM
Catholic Damage's Avatar
sup chris. still cant beleive youre goin bigger on that thing.....
