Turbo Blankets
Old Jul 18, 2018 | 03:59 PM
  #21
BlackGMC's Avatar
Resident Retard
Wrap the AC dryer and tranny lines. Get stupid with the plug wires too.
Old Jul 18, 2018 | 07:16 PM
  #22
AkSSS's Avatar
Yep. I wrapped my ac line with the same titanium header wrap as all my pipes. I did wrap my turbo log also, but not my drivers side manifold. that would be a bitch. That's why I chose to ceramic coat everything first. Everything helps.
Old Jul 19, 2018 | 08:50 AM
  #23
MrHorsepowerLSx's Avatar
11 Second Club
Originally Posted by Atomic
Yes. Wrap everything. I double wrapped all my pipes and double sleeved plug wires and still melted some.
I second this as well, I wrapped EVERYTHING on my truck 2x as well and some places even got
3x layers of wrap applied, I have been expirmenting with ways of wrapping the turbo and then using a double blanket on it, some of the ideas are good but don’t really fit the physical aspects of it
Old Jul 19, 2018 | 09:14 AM
  #24
03sierraslt's Avatar
So what should I ballpark I need for wrap if using 2”? How many feet? I figure the 4” downpipe will use a decent amount.
Old Jul 19, 2018 | 09:44 AM
  #25
Atomic's Avatar
I have a gauge for that
Youll want the 1" for the headers as they are much tighter radius, but the 2" works well on the rest of the pipes. I think I used 50ft per wrap per side on the headers, and something like 100ft for the crossover and downpipe per wrap, depending how far you want to go.
Old Jul 19, 2018 | 09:48 AM
  #26
Ok. Sounds good
Old Jul 19, 2018 | 02:17 PM
  #27
11 Second Club
I want to say I used about 200-250ft. Of wrap on my system, I have a 3” DP tho, but I wrapped it all the way from turbo outlet to the inlet on the 4” system and a bit past. Then back up again. I found the 2” stuff to work great, and areas where it was a bit tight I just trimmed it and tucked it around the merge pipes to fit extra snug
Ohh yeah FWIW I used this “flexible foil wrap” that I collected over the years from
Installing Banks Power Paks on motorhomes, but it is like 6”x18” long 1/16th thick foil with dimples on the outside and ultra high heat fiberglass on the inside with another layer of 1/16th thick foil....... I have it as a heat shield protecting my drain hose from the WG ( they are very close on my setup ) but you may be able to purchase some from Banks directly, I have been working on a way to may a right fitting “helmet” for the turbo housing using that material followed by a blanket and some wrap and another blanket
Old Jul 19, 2018 | 05:03 PM
  #28
skolman91's Avatar
Like this stuff?
I had a similar idea for using it and wondered what else you could use this stuff for, but for headers like in the video i think its mostly worthless unless you just need to shield something close..
Old Jul 19, 2018 | 09:25 PM
  #29
Hmm. Well, this is a big bitch. Should cool nicely.
Old Jul 19, 2018 | 10:51 PM
  #30
Wheatley's Avatar
Truck Sponsor
Nice!! You’ll like it!!
