turbo back pressure ??'s
Old Nov 3, 2009 | 07:02 PM
TURBHOE's Avatar
Default turbo back pressure ??'s
anybody ever logged back pressure in one of the truck turbo setups? i think i'm going to do mine one on hot pipe another on the down pipe.
Old Nov 3, 2009 | 07:09 PM
charcold-bowtie's Avatar
I havent but I will if the new setup ever gets to moving. I dont think ive ever seen anything about one in the DP tho?
Old Nov 3, 2009 | 07:11 PM
1st_TACO's Avatar
just curious as to why you have a concern about it? do you think you are choking your motor?
Old Nov 3, 2009 | 07:26 PM
Coban's Avatar
Kind of.
https://www.performancetrucks.net/fo...&postcount=342
Old Nov 3, 2009 | 07:47 PM
TURBHOE's Avatar
not sure what is doing. i want to find out though. i want a new cam and i want to see what the pressures are before i buy one.
i want to log the downpipe to make sure that's not where the back pressure is from. if that makes sence.
Old Nov 3, 2009 | 08:00 PM
1st_TACO's Avatar
totally understand...ill try to find a build thread so i can see what your working with..
i know i dont have an ls based motor, but i do know some turbo stuff
Old Nov 3, 2009 | 09:56 PM
parish8's Avatar
single digit dreamer
this was awhile back >> https://ls1tech.com/forums/forced-in...check-out.html
Old Nov 4, 2009 | 07:01 AM
TURBHOE's Avatar
that part is easy, stock 5.3l with p&p ls6 heads and patriot springs. stock gaskets and arp studs, 2003 ls6 cam. its got trick hot pipes and a tc78 with the f1 68mm exhaust wheel inside a .96 A/R housing. it has a 3" downpipe to a 4"diesel exhuast with huge magnaflow muffler.
Originally Posted by parish8
you had some pretty good back pressure there. what turbo and exhaust side (wheel size and A/R) did you have on there? hope its less for my 5.3l.
Old Nov 4, 2009 | 09:13 AM
Wilde Racing's Avatar
How do I change this text
Originally Posted by Coban
My front mount was a log style manifold, but with a split scroll T-6 housing. I can post up more pictures and information on my EBP set-up
Old Nov 4, 2009 | 09:30 AM
TURBHOE's Avatar
sometime i wish i could get a t6 housing for my turbo but i can't. i want to find out about a bigger housing for mine though.
