turbo acting stupid
IMO NO f/i system should be mail order tuned..... Too many variables
Get a wideband and a real tune in that thing before you fry that motor and slag your turbo and you have a shiny pile of junk....
Mine did the same thing under certain conditions. I don't know if this will help.
I changed to a way cooler burning plug, gapped them at 32, changed the maf sensor, map sensor, and had it dyno tuned. That solved everything.
Good luck. Get it tuned
thanks again...yeah i got a cold plug gapped at 35, still running the maf...looking around for a dyno tune shop right now...probably gonna have to go to el paso tx for that...untill i get it fixed ill just car pull to base with a buddy haha
the meth nozzle is about 12 inches from throttle body....well i called some places about dyno tuning...i think el paso is gonna be about my best shot. my buddys around here took there gto's and stuff out to arizona. but the shop in el paso says $295...that sounds good right...
When I first started tuning with meth it would go extremely rich and shutter like your truck. I'm not sure what's going on with your setup but an extreme rich or lean condition will cause the sensation that you are feeling. You need to get that thing tuned on a dyno ASAP.
Also, if it is a lean condition you need to get it tuned asap even if you do have to pay a little more.
