Turbo
Old Mar 16, 2017 | 05:28 PM
Jetn3's Avatar
Oh yeah, fuel pump and injectors too
Old Mar 16, 2017 | 05:29 PM
FFDP's Avatar
I didn't even see the 2006 year listed, those already have the better rods. The weaker rods are from 99-03/04.
If the other motor you get is an older LM7, check the year or see what the rods look like.
Old Mar 16, 2017 | 06:12 PM
20Silverado06's Avatar
Registered User
Thanks,it'll be daily driven so I'll upgrade to a 4L80E
Once I'm ready I'll keep y'all updated
Old Mar 16, 2017 | 06:13 PM
Registered User
Thanks
Old Mar 16, 2017 | 07:14 PM
Registered User
Also do y'all happen to know the cubic inch of an LM7 ??
Old Mar 16, 2017 | 07:48 PM
FFDP's Avatar
5.3's are 325 cubic inches.
Old Mar 16, 2017 | 10:31 PM
GMCtrk's Avatar
Originally Posted by FFDP
Sloppy mechanics has a 265,000ish mile junkyard 6.0 pullout with a cam swap making over 800whp. It made 992 once or so and he's going for 1000whp on the stock crank with gen 4 connection rods and stock pistons. He's got tons of video's on youtube about it all.
Several on this forum have made 1000 on stock 6 liters.
Synergy made high 800s on a stock 5.3 years ago.
Old Mar 17, 2017 | 03:48 PM
zero2sixT's Avatar
Originally Posted by ezdaar
A bone stock 150k mile 5.3 will eat 10psi and ask for more, 24/7 365.
Yeah, because the piston rings are worn a little bit and allow blow by.
Op,
If you rebuild the 5.3, go with forged pistons. Rods and crank have been proven to handle pretty good power.
Old Mar 20, 2017 | 04:14 AM
ezdaar's Avatar
Sloppy just broke the 1k barrier on stock bottom end and heads.
He finnaly swapped to new head gaskets and arp head studs.
He routinly hit 800+ on 100% oem highly used (250k) pull out engines with rods from random engines, head gaskets used many many times.
Check out his youtube channel, sloppy mechanics. You will be blown away with how much power this guy makes on cobbled together engines.
http://www.yellowbullet.com/forum/sh....php?t=2157841
Old Mar 20, 2017 | 10:45 AM
kbracing96's Avatar
You must have missed a vid, lol. This motor had reused ls9 head gaskets and re used STOCK head bolts!! Crazy! lol
