turbo 5.3 blowing white smoke
Old Aug 7, 2019 | 08:23 PM
Kws82590's Avatar
Default turbo 5.3 blowing white smoke
so i took the truck out today to do some data logging and did a small pull while getting on the freeway and truck went pig rich and wouldn't let me accelerate past 4500 and was bogging out so i got off the highway and everything was running fine i pulled into a parking lot to save the log and let the truck idle for about 3 min then turned it off and did everything i needed to on the computer and turned the truck back on and it started blowing white smoke out the exhaust so i popped the hood and noticed i had a lot of smoke coming out of my blow by also coolant level is where it has always been and oil pressure was good around 40psi at idle any ideas?
Old Aug 7, 2019 | 08:42 PM
ILuvJDM's Avatar
Blown head gasket
Old Aug 7, 2019 | 10:10 PM
Kws82590's Avatar
even though no coolant loss?
Old Aug 7, 2019 | 10:13 PM
arthursc2's Avatar
Can neither confirm nor deny the diagnosis, but I know it doesn't take a lot of coolant to burn white
Old Aug 7, 2019 | 11:51 PM
Kws82590's Avatar
Also having a lot of what appears to be steam or smoke coming our of my catch can
Old Aug 8, 2019 | 05:22 AM
RySmDPT14's Avatar
Under boost can be causing the head gasket to expose a leak, as it’s trying to separate head from block any weak point in head gasket will show up.
Old Aug 8, 2019 | 12:45 PM
terravast4's Avatar
castech heads maybe?
bluebommer07
16
Oct 29, 2013 07:32 PM
Chevyboss22
Jan 19, 2012 02:10 PM
orange1500hd
Aug 11, 2010 09:52 PM
LVSTOGOFST2002
Oct 20, 2005 05:51 PM
DanaliHD
Dec 30, 2004 05:43 AM
