View Poll Results: which turbo setup would you recommend is best?
front mount setup with intercooler
28
87.50%
rear mount setup with intercooler
12.50%
Voters: 32. You may not vote on this poll
Turbo
Old Oct 25, 2007 | 01:49 AM
VINCE's Avatar
Shorty Director
I am for it depends on what you are using it for and also which truck. I.E., EXT cab, Crew Cab, Dually, etc.. Weight matters especially in your choice of turbos and the load that is going to be put on the turbos..
Old Oct 25, 2007 | 03:19 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Front mount.
Old Oct 25, 2007 | 08:46 AM
it is going in a reg cab 2wd silverado and i am shooting for the most hp i can get out of it.
Old Oct 25, 2007 | 11:18 AM
WJ MARK's Avatar
Front Mount
Old Oct 25, 2007 | 11:25 AM
kbracing96's Avatar
A front mount and a rear mount at the same boost will make about the same peak HP and run about the same 1/4 miles speed, cuz you will brake stall them in to boost either way. Where the difference will be is on the street, A front mount will spool faster, just cuz there is less pipe to fill and it's getting hotter, more expanded gases from the exhaust. It will just depend on if you want the hot turbo under the hood, or a little cooler turbo and a little more lag on the street with it under the bed.
Old Oct 25, 2007 | 06:32 PM
Spoolin's Avatar
GFYS and STFU
If that's the case then I would go Front mount! But be prepared to deal with underhood heat which may affect your DD'ing ability on serious HP applications.
Old Oct 25, 2007 | 07:02 PM
dan96z71's Avatar
Got mine on order right now. Getting black ceramic coating on it.
Old Oct 26, 2007 | 11:53 AM
Bad_Apple's Avatar
Man that front mount kit look sweet, I'm probably couple more years going to switch from Procharger to a Front mount turbo kit.
kha4079
Oct 29, 2018 04:38 PM
lxcoupe
Sep 6, 2017 08:24 AM
jtphelps289
Sep 11, 2015 06:37 PM
slowswb
Sep 5, 2015 02:27 PM
06murder
Sep 4, 2015 03:54 PM
