View Poll Results: which turbo setup would you recommend is best?
front mount setup with intercooler
28
87.50%
rear mount setup with intercooler
12.50%
Voters: 32. You may not vote on this poll
Turbo
I am for it depends on what you are using it for and also which truck. I.E., EXT cab, Crew Cab, Dually, etc.. Weight matters especially in your choice of turbos and the load that is going to be put on the turbos..
A front mount and a rear mount at the same boost will make about the same peak HP and run about the same 1/4 miles speed, cuz you will brake stall them in to boost either way. Where the difference will be is on the street, A front mount will spool faster, just cuz there is less pipe to fill and it's getting hotter, more expanded gases from the exhaust. It will just depend on if you want the hot turbo under the hood, or a little cooler turbo and a little more lag on the street with it under the bed.
lxcoupe
Sep 6, 2017 08:24 AM
jtphelps289
Sep 11, 2015 06:37 PM
06murder
Sep 4, 2015 03:54 PM
