Trick turbo ???
Old Aug 4, 2016 | 05:55 AM
gmc6.0's Avatar
Default Trick turbo ???
I'm in the market for a new hot parts kit. can someone tell if the accel ceramic coated wires will fit the trick kit? I spent a lot of money going through several different companies and found them to last so far. I'm on a budget so cost is everything to me.
Old Aug 4, 2016 | 07:20 AM
cwalker2006's Avatar
I would like to know as well!
Old Aug 4, 2016 | 07:56 AM
Choda's Avatar
https://www.performancetrucks.net/fo...tested-522108/
I did not test accel but this is still worth a read. I still use Granatelli and they fit perfectly with my trick manifold. I think every wire would fit its just about the OHM and "extra" wire that you might have looped or hanging around.
Old Aug 4, 2016 | 08:37 AM
TrickTurbo's Avatar
Truck Sponsor
I can not say for sure never used those wires.
Are they larger then your standard msd wire?
Here's a quick video showing clearances on these 3 types of angles.
Msd multi angle
45'
And straight think this was a stock replacement wire. No shield.
lxcoupe
Jun 11, 2016 11:18 PM
drexel
May 31, 2016 02:55 PM
GM1697
May 22, 2016 08:35 PM
rocknZ71
May 18, 2016 08:29 PM
01SilveradoJakee
May 18, 2016 08:15 PM
