Trick turbo ???
I'm in the market for a new hot parts kit. can someone tell if the accel ceramic coated wires will fit the trick kit? I spent a lot of money going through several different companies and found them to last so far. I'm on a budget so cost is everything to me.
https://www.performancetrucks.net/fo...tested-522108/
I did not test accel but this is still worth a read. I still use Granatelli and they fit perfectly with my trick manifold. I think every wire would fit its just about the OHM and "extra" wire that you might have looped or hanging around.
Are they larger then your standard msd wire?
Here's a quick video showing clearances on these 3 types of angles.
Msd multi angle
45'
And straight think this was a stock replacement wire. No shield.
