trick performance PROPS!!!!!
Old Mar 6, 2008 | 09:37 AM
  #61
TURBHOE's Avatar
so i don't want it opem at just idle vacuum? oops i made sure it was lol. i can tighten down the bolt on top of it.
Old Mar 6, 2008 | 09:38 AM
  #62
TURBHOE's Avatar
so what do these ***** look like? oops i mean slots
Old Mar 6, 2008 | 10:24 AM
  #63
I do my best these days to stay away from *****, there just trouble.
Its the slot by the wheel. It sucks from the outside and lets air reserculate when under boost but not enough airflow.
Old Mar 6, 2008 | 10:25 AM
  #64
It also helps improve total airflow and efeciency by 10%.
Old Mar 6, 2008 | 10:45 AM
  #65
ZZebes's Avatar
what is a wastegate suppose to sound like when it opens? my tahoe was making a like farting sound after it hit ten pounds. is this valve float or wastegate opening.
I just thought of something, i remember reading in the garret Turbo 103 page about compressor flutter or surge if your compressor wheel is to large and you are operating to the left of the surge line on the compressor map
Originally Posted by Garret Turbo 103
Surge is the left hand boundary of the compressor map. Operation to the left of this line represents a region of flow instability. This region is characterized by mild flutter to wildly fluctuating boost and “barking” from the compressor. Continued operation within this region can lead to premature turbo failure due to heavy thrust loading.
Surge is most commonly experienced when one of two situations exist. The first and most damaging is surge under load. It can be an indication that your compressor is too large. Surge is also commonly experienced when the throttle is quickly closed after boosting. This occurs because mass flow is drastically reduced as the throttle is closed, but the turbo is still spinning and generating boost. This immediately drives the operating point to the far left of the compressor map, right into surge.
Surge will decay once the turbo speed finally slows enough to reduce the boost and move the operating point back into the stable region. This situation is commonly addressed by using a Blow-Off Valves (BOV) or bypass valve. A BOV functions to vent intake pressure to atmosphere so that the mass flow ramps down smoothly, keeping the compressor out of surge. In the case of a recirculating bypass valve, the airflow is recirculated back to the compressor inlet.
so according to that your part throttle "farting sound" could be compressor surge
Old Mar 6, 2008 | 11:23 AM
  #66
TURBHOE's Avatar
sounds about right. guees i should stop doing 10lbs at part throttle. lol. but its so easy. i mean come on 40& throttle and 7-10lbs. well i went wot with my new tune. wooo that was crazy. i thought the front end was gonna lift. it squated before but damn. and fuel was at 11.2-11.3ish the whole time. gonna do more tonight.
Old Mar 6, 2008 | 11:26 AM
  #67
ZZebes's Avatar
What size turbo are you using
Old Mar 6, 2008 | 11:36 AM
  #68
TURBHOE's Avatar
t4/t04r compressor: TO4R
.70 a/r 66.5mm inducer flow: 75 lbs/min 960cfm 360* thrust bearing standard turbine: T4
so its bigger than the t66 but smaller than the 67.
Old Mar 6, 2008 | 11:38 AM
  #69
ZZebes's Avatar
Imma crunch some numbers i'll be back
Old Mar 6, 2008 | 11:45 AM
  #70
TURBHOE's Avatar
ok, cool oh and .84 A/R i think it was. prabably p trim
