torque management
Old Oct 25, 2015 | 08:28 PM
tim wellington's Avatar
Default thanks
Originally Posted by megabuddys
For the torque management stuff, Go into Transmission > Torque management> Torque reduction and adjust whatever. You can also go into Engine> Torque Management > Spark retard and cut those down to zero, to zero it out or tune it also. You have an 80 so you can take it all out if wanted. On the 60's cut it down to 50-75 percent from stock settings and only enable it from 480ft lbs up, it works very well. I am running 800ish fwhp on a 60e in a 4300 lb 4x4 vehicle, it works awesome
sent u a pm
Old Oct 29, 2015 | 02:08 AM
turbo freak's Avatar
Can you post pictures of your trans torque reduction tables?
i have two 4x4 trucks with supercharger and built 60e. I do always wonder what is the best way to set that tables. right now i have zeroed all of them but i am not sure. One of them fail very often and it is the best built!
Old Oct 30, 2015 | 08:57 AM
slowec's Avatar
Zero that TM and lock those timing tables to 12. if you are still getting 8 degrees and have no KR, you have not found the culprit table yet. Keep looking and asking around until you find it.
Old Oct 31, 2015 | 03:23 AM
megabuddys's Avatar
I will later today for ya.
Old Nov 4, 2015 | 11:13 AM
Default torgue management
all off .thanks for replys got new 13-14psi (from 9psi) more timing 15deg (from 9-10 deg) with meth .its a new animal .thanks jamie (tuner)and jason(slowec)
mhotrodscooter
Dec 21, 2015 02:39 AM
cookster489
Nov 5, 2015 02:06 PM
EmmerichLSx
Oct 7, 2015 08:39 AM
jamesm32
Sep 24, 2015 11:49 AM
