torque management
Old Oct 23, 2015 | 11:04 AM
tim wellington's Avatar
Default torque management
2002 gm800 computer .how do completely disable torque management i have it max 640 .is there any thing else .computer thinks i have 4l60e but i have 4l80e with relay method for switch .
Old Oct 23, 2015 | 11:34 AM
Gadgetized's Avatar
What tuning software are you using? Can you post your tune?
Old Oct 23, 2015 | 11:42 AM
kbracing96's Avatar
On a side note, how is the relay method working for you? Really thinking of trying it on my truck, hate the way it unlocks all the time on the highway when I let off the gas.
Old Oct 23, 2015 | 01:14 PM
Gadgetized's Avatar
^^ you could do a HPT EFI Live hybrid tune.
Default soft ware
hp tuner
Old Oct 23, 2015 | 01:15 PM
Default relay
love it no complaints
Old Oct 23, 2015 | 05:12 PM
kbracing96's Avatar
I've thought about that, but its a bunch of work, lol. I even have both.
Old Oct 23, 2015 | 06:23 PM
1FastBrick's Avatar
Custm2500's Rude Friend
A friend told me you have better control over the **** times doing it this way. He wont go back to the segment swap as he liked the control he has doing it this way. He says he gets a faster, firmer shift.
I my self have never done it or driven a truck that was set up that way so I am not sure of the actual difference.
Old Oct 25, 2015 | 03:02 AM
megabuddys's Avatar
Hmm, I did a segment swap on one and getting it to stay locked was just a couple settings. 6.0/76mm 4l80 with triple disc and he pulls an 18ft enclosed car trailer. The factory settings are terrible. Drives you nuts unlocking everytime you let off the throttle. Hp Tuners btw
Old Oct 25, 2015 | 03:13 AM
megabuddys's Avatar
For the torque management stuff, Go into Transmission > Torque management> Torque reduction and adjust whatever. You can also go into Engine> Torque Management > Spark retard and cut those down to zero, to zero it out or tune it also. You have an 80 so you can take it all out if wanted. On the 60's cut it down to 50-75 percent from stock settings and only enable it from 480ft lbs up, it works very well. I am running 800ish fwhp on a 60e in a 4300 lb 4x4 vehicle, it works awesome
