Timing+Boost+Octane
Old May 30, 2012 | 09:01 PM
yea it sounds like I was pushing it at 13psi, 16 degrees of timing on 93 octane only
Old May 30, 2012 | 10:24 PM
05_quick4door's Avatar
Not a 5.3 so it has very little relavents but
19 lbs 24 degrees timing. E85
Old May 30, 2012 | 10:40 PM
LS1FREEK's Avatar
13 Second Truck Club
We did 10* with 12-13 psi on 91 oct in my brothers 4.8, and the afr was 11.5. Stock long block with an Isky triple 12 cam and a ball bearing 76mm turbo. Could mabe have pushed it harder but idk...
Old May 30, 2012 | 10:56 PM
Atomic's Avatar
I have a gauge for that
15deg with 16psi with 25% e85/ 75% 93 spraying meth from dual nozzles...
might be overly safe but im trying to avoid this happening again...
Old May 30, 2012 | 11:45 PM
lglowe's Avatar
What fuel, boost, and timing caused that? And it seems like mixing 25/75% e85 93 could be a pain in the *** sometimes.?
Old May 31, 2012 | 12:19 AM
Atomic's Avatar
That was 15psi 15deg on only 93...
Its not bad, I made a spreadsheet that calculates the new stoichometric afr based on how much I add to the tank so I just have to change one number in the tune and everything else is correct.
Old May 31, 2012 | 04:43 AM
schino's Avatar
13#, 18 deg, 93 oct, 100% meth out of m15 nozzle, 10.8 afr
Old May 31, 2012 | 08:21 AM
kbracing96's Avatar
I run an E85 25/75 mix a lot too. It's not bad if you have a WB gauge. You see it running a little rich or lean, you just go to the gas station and add a little gas or E85 to get it where you want to. Don't even have to mess with the tune once its close.
Old May 31, 2012 | 09:22 AM
Choda's Avatar
Good thread!!!
Old May 31, 2012 | 10:59 AM
Been on 10psi 18* of timing on 91 octaine, so far my lq4 has held up to my abuse for 2 years
