Timing+Boost+Octane
Old May 30, 2012 | 08:59 AM
Default Timing+Boost+Octane
OK this thread is for people to post up what PSI, timing and octane they are running. Ive been scratching my head trying to figure how hard I can push my 5.3 with 93 pump gas so hopefully this thread will help. When I had the truck tuned it was tuned for 9psi and 16 degrees of timing. I recently turned it up to 13psi to beat a modded 5.0 and I was wondering how safe it is. I know I shouldnt have done it without running a log to see if I have any KR but it ran like a scalded dog. AFR was right at 11.0. How much boost/timing can I safely run on pump 93 octane? No meth right now and E85 is out of the question in Louisiana.
Old May 30, 2012 | 09:36 AM
slowec's Avatar
You bumped it up to the same psi as I did trying for 6's in the 1/8th. I was only at 12.5 degrees of timing on 93 though.
I take it your sig needs updating...
Old May 30, 2012 | 09:59 AM
Lucille's Avatar
What I would like to see is a screen shot of somebody's log showing nothing but RPM, Boost, and Timing from idle to redline.
Old May 30, 2012 | 10:07 AM
nonnieselman's Avatar
im gonna have to look at my old tune/logs, but i wanna say i was running 18* at 6psi on 93 oct..
Even used the same timing for the 47 shot and never heard it complain
Old May 30, 2012 | 10:20 AM
03sierraslt's Avatar
10-11psi, 18-19 timing, 93 oct with some meth
Old May 30, 2012 | 10:21 AM
If i can find my jump drive ill do that at lunch time.
Old May 30, 2012 | 12:23 PM
Yea it needs a little updating lol. I guess I need to do some logs and see what's happening
Old May 30, 2012 | 12:36 PM
smokeshow's Avatar
Mod with training wheels
22psi, 16°, 50/50 E85/91.
Old May 30, 2012 | 08:43 PM
blue0453's Avatar
13psi, 11 degrees timing, 50/50 meth/water, 11.5 afrs..
Old May 30, 2012 | 08:57 PM
Last Call's Avatar
TOTM: January 2007
I don't think any 2 combos will be the same - intake temps, compression ratio, and where the timing is plays a factor in how much you can run.
