Time to make more boost...
Old Aug 6, 2008 | 10:08 PM
BigKID's Avatar
Default Time to make more boost...
I have been letting this blower loft along for far too long so I got a few things to help it out.
New PTM 95mm throttle body on left, stock 76mm on right...
back side comparison of the two...
I am currently running a ported stock throttle body with a 4" pulley making 5.5-6.5# (dependent of weather). With the 3.25" pulley and throttle body below, I should be pushing close to 15#.
I am going to change just the throttle body first to see if I gain any boost with the 4" pulley then I will install the 3.5" to see if I get the 11-12# I expect; then will move down to the 3.25" for 14-15#. I anticipate having some belt slip with the 3.25 so I will be getting some 100mm idler pulleys to add some belt wrap until I can do the 8-rib swap.
Should be fun once I get it tuned out.
Old Aug 6, 2008 | 10:12 PM
chevrolade's Avatar
Nice!!you Converting To A 4 Bolt Tb?
Old Aug 6, 2008 | 10:18 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Step up to the plate! Nice looking TB unit. Post up your results here!
Old Aug 6, 2008 | 10:29 PM
BigKID's Avatar
The KB J-tube uses a 4-bolt flange. I am currently using an adapter to use the stock 3-bolt.
Old Aug 6, 2008 | 10:31 PM
Stoichiometric's Avatar
15lbs ought to do it. Are you tuning yourself?
Old Aug 6, 2008 | 10:35 PM
BigKID's Avatar
Yes, with HPT. I am currently running a MAF tune but have a 2-bar map sensor on the way so I can convert to 2-bar SD.
Old Aug 17, 2008 | 10:13 PM
BigKID's Avatar
Got the 3.5" installed along with a new belt (110.5") and some new intake piping. Took it for a quick drive this afternoon and saw a steady 9# on the first short hit. Second time I tried it the boost gauge was floating between 6-8# so I presume I am getting some belt slip which was confirmed by the maf readings on the scan. I have two Billetflow 100mm idlers to add now. Just have to figure out some spacers for them. Now for a few pics...
Before:
Now:
Old Aug 17, 2008 | 10:52 PM
WJ MARK's Avatar
sweet setup! Should run good!
Old Aug 18, 2008 | 08:15 AM
quicksilverado's Avatar
Looking good Kenny.
Old Aug 18, 2008 | 08:23 AM
TrickTurbo's Avatar
Truck Sponsor
Very Clean..... is the first pick stock from KB?
