Time to cam the radix 5.3, suggestions...
Old Dec 14, 2005 | 09:35 PM
Last Call's Avatar
TOTM: January 2007
Originally Posted by moregrip
Sounds like your a candidate for the GT7 then
As far as my cam selection goes, I've not made that decision yet.
Im going to call Lingenfelter tomorrow and see what they suggest. Will post back tomorrow.
Just a bit confused on whether to go with a proven performer or try something new. A cam swap is time intensive and/or costly if done by a mechanic.
Old Dec 14, 2005 | 10:05 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by j's01silverado
The intake and exhaust duration are quite close to the GT2-3 cam, however the lsa is quite different. I wonder how the lsa differential affects hp and tq?
My cam 210/218 551/551 overlap 52*112lsa POWER RANGE 1900 TO 6000
Other cam 210/218 551/551 overlap 48* 116lsa POWER RANGE 1500 TO 5800
I'm not sure of the GT2-3 cam specs but it looks as is if the higher lsa pushes the powerband down. Not sure if the over lap play into that.
Check out http://www.vincihighperformance.com/...s%20truck.html They have a good breakdown of specs and powerbands.
Old Dec 14, 2005 | 10:32 PM
8ALTNG's Avatar
I would ask Flyer. I believe that he has the fastest time with a radix'd 5.3liter. He should be able to point you in the right direction
Old Dec 15, 2005 | 02:07 AM
The_Mexican's Avatar
Any dyno or track time improvements with cam swap? Any loss in boost?
I don't have any dyno or track numbers (by the time I went to the track I also added the 2.90 pulley so it won't be any accurate info on the cam) but I can assure you it was pretty quick with that cam, power from 2500 rpm and up.
The truck lost 1.5psi but the was faster, pulled a lot harder.
The other cam i tried was a 222/226 .562/.568 115° lots of power but all of it at high rpms and the idle was very choppy, too big for the 5.3L i guess, i really like the 212/218 high lift better.
Good luck with your cam choice.
Old Dec 15, 2005 | 05:22 AM
tdrumm's Avatar
Wasn't his cam the Comp 216/220 on a 115 lsa?
Old Dec 15, 2005 | 05:24 AM
tdrumm's Avatar
Wasn't his cam the Comp 216/220 on a 115 LSA.
Generally for a boosted application you'd want more duration on the exhaust, and a higher LSA to help bleed off cylinder pressure.
Old Dec 15, 2005 | 11:20 AM
Last Call's Avatar
TOTM: January 2007
Just spoke with tech support from Lingenfelter and they recommend the gt 7 (210/230 on 121lsa) as it is there cam of choice for the magnacharger. They said they average about 20-30hp with this cam.
Brian/Blownchevy went with the the gt2-3 cam and got 44rwhp. specs are 207/220 on a 118.5lsa.
I guess I have more research to do...
Any suggestions???
Old Dec 15, 2005 | 11:22 AM
moregrip's Avatar
what a rush!
Any suggestions???
that was with extensive tuning as well though, not just a cam install and go
Old Dec 15, 2005 | 11:28 AM
Last Call's Avatar
TOTM: January 2007
Im sure Brian had good rationale on going with this cam. I just wish I knew what it was. If the gt 7 was a better cam, i think brian would have went with it.
I plan to ask oxidizer or crash dummy to tune it when the cam swap is complete. Drive down to socal, get my truck tuned and go to a private track day with all you socal guys. I was hoping for sometime in the spring.
Gotta make this cam choice first though..
Old Dec 15, 2005 | 12:06 PM
KySilverado's Avatar
NakedAv and I had great luck with the cam in my signature.
