Time to cam the radix 5.3, suggestions...
Originally Posted by moregrip
Sounds like your a candidate for the GT7 then
As far as my cam selection goes, I've not made that decision yet.
Just a bit confused on whether to go with a proven performer or try something new. A cam swap is time intensive and/or costly if done by a mechanic.
Originally Posted by j's01silverado
The intake and exhaust duration are quite close to the GT2-3 cam, however the lsa is quite different. I wonder how the lsa differential affects hp and tq?
Other cam 210/218 551/551 overlap 48* 116lsa POWER RANGE 1500 TO 5800
I'm not sure of the GT2-3 cam specs but it looks as is if the higher lsa pushes the powerband down. Not sure if the over lap play into that.
Check out http://www.vincihighperformance.com/...s%20truck.html They have a good breakdown of specs and powerbands.
Any dyno or track time improvements with cam swap? Any loss in boost?
The truck lost 1.5psi but the was faster, pulled a lot harder.
The other cam i tried was a 222/226 .562/.568 115° lots of power but all of it at high rpms and the idle was very choppy, too big for the 5.3L i guess, i really like the 212/218 high lift better.
Good luck with your cam choice.
Originally Posted by 8ALTNG
I would ask Flyer. I believe that he has the fastest time with a radix'd 5.3liter. He should be able to point you in the right direction
Generally for a boosted application you'd want more duration on the exhaust, and a higher LSA to help bleed off cylinder pressure.
Just spoke with tech support from Lingenfelter and they recommend the gt 7 (210/230 on 121lsa) as it is there cam of choice for the magnacharger. They said they average about 20-30hp with this cam.
Brian/Blownchevy went with the the gt2-3 cam and got 44rwhp. specs are 207/220 on a 118.5lsa.
I guess I have more research to do...
Any suggestions???
Any suggestions???
Any suggestions???
Any suggestions???
Im sure Brian had good rationale on going with this cam. I just wish I knew what it was. If the gt 7 was a better cam, i think brian would have went with it.
I plan to ask oxidizer or crash dummy to tune it when the cam swap is complete. Drive down to socal, get my truck tuned and go to a private track day with all you socal guys. I was hoping for sometime in the spring.
Gotta make this cam choice first though..
