Throttle body on TVS 1900
I have the Tvs1900. And it currently has the 3 bolt throttle body and I wanted to upgrade to the 4 bolt throttle body and install the 90 mm throttle body and was wondering where y'all buy the adapter plate or how to get it changed over?
Thanks for y'all's help
Yes, your TVS should already be setup for a 4 bolt 90mm. If you are running the 3 bolt 78mm then you will have a adapter plate behind the TB that you remove and the 90mm should bolt right up. I sent you a link with some info.
