Those with an LS6 valley cover and boost guys come in please!!
Old Jun 28, 2010 | 09:24 PM
allballz57's Avatar
Default Those with an LS6 valley cover and boost guys come in please!!
How are you running your pcv system with a boosted motor and LS6 valley cover? I am routing this stuff soon and want to do it right the first time,I have read a bunch of threads and have not seen a definitive answer! Are you still using a pcv valve and catch can?with air breather or not?I don't think my last setup with the procharger was right as I was seeng a LOT of oil in the charge pipe so I want to make sure it is right this time!Thnks for the help guys!
Old Jun 28, 2010 | 10:12 PM
Bluchevypick's Avatar
I havent done it yet but i was told just to put a breather on both valve covers but i havent heard what to do with the valley cover either so i would like to know also Brent.
Old Jun 28, 2010 | 10:38 PM
MikeGyver's Avatar
I gave up, the pcv system was allowing oil into the intake with an LS6 valley cover and catch can. Now I pollute the air and leave a puddle in the driveway.
Old Jun 29, 2010 | 07:53 AM
allballz57's Avatar
Damn,I was hoping to get some positive response's.I don't want to deal with the "oil" smell at all,and I definately don't want to be pressurizing the crankcase.
Old Jun 29, 2010 | 09:52 AM
Doobie's Avatar
PCV valve will plug into a nipple at the front of LS6 valley cover. Plug your existing/stock rocker cover PCV location. The LS6 cover should come with a rubber hose adaptor to accomadate your PCV valve. Very simple & clean install. Mine dosen't pass any oil at all.
Old Jun 29, 2010 | 11:40 AM
Casey2323's Avatar
Default well
I dont smell anything.. no oil leak.... I run three ten dollar filters one on each valve cover and one on the ls6 intake.... but i have a built wcch motor with little leakdown
Old Jun 29, 2010 | 02:08 PM
skoal bandit's Avatar
PM skipperdaddy. i think he has the ls6 valley cover and he's supercharged. Maybe iamkeniff can can give you an answer too. he helped skipperdaddy.
Old Jun 29, 2010 | 03:00 PM
MikeGyver's Avatar
I'm planning on trying a "pan-e-vac" system, the system that uses exhaust pulses and a reed valve to suck the crankcase fumes into the exhaust pipes. I'm going to tee the valley and valve covers into a catch can, and then into the exhaust. I hate the smell of the fumes, too. It's not oil, it's unburned fuel. I'd rather clog up the cats with the blow-by instead of putting it into the intake.
Old Jun 29, 2010 | 04:05 PM
allballz57's Avatar
What do you do with the passenger side valve cover line? and are you running any filters?
Old Jun 29, 2010 | 04:06 PM
allballz57's Avatar
Do you have any pis of this?
