And they said it wouldnt fit....5" DP
Old Dec 15, 2012 | 06:14 PM
  #41
Atomic's Avatar
I have a gauge for that
We had to crush the 4" to get it to fit so no beuno on a 5" without going under all the crossmembers (no ground clearance). I like the idea of being able to somewhat limit power with the cutout closed though. Who makes a 66" Largest one tial or jgs make is a 60...
Theres not really a good spot for another gate without going over the top of the engine
Old Dec 15, 2012 | 06:33 PM
  #42
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I call BS. You're gonna need to post up a rwd dyno sheet to prove that is a 5" dp!
Old Dec 15, 2012 | 06:35 PM
  #43
Atomic's Avatar
haha, youre right, its photoshopped
Old Dec 15, 2012 | 06:57 PM
  #44
TrickTurbo's Avatar
Truck Sponsor
Precision. 66mm
Old Dec 15, 2012 | 07:22 PM
  #45
Gadgetized's Avatar
I know you are restricted with space, but I always wondered if it would make a difference if the air entered the wastegate in a straight shot. They are suggested to be installed that way. When I made my crossover, I put 2 45's in it instead of a 90 so I could install the wastegate there. It will be a straight shot in, and straight out as it will tie into the exhaust when it comes out of the gate. It will merge into the bottom of the 4" exhaust pipe so it won't be perfectly straight.
Old Dec 15, 2012 | 07:27 PM
  #46
phasemaster1's Avatar
For some reason I think that 5" DP is going to affect global warming. Do you think that fender well is going to survive? Nice work.
Old Dec 15, 2012 | 08:45 PM
  #47
I AM A MOTHERF*CKER
Did you make that dp in excel???
Old Dec 16, 2012 | 10:26 AM
  #48
JoeyGC5's Avatar
Kickass upgrade, subscribing to see the end result of wastegate upgrade
Old Dec 16, 2012 | 01:39 PM
  #49
brent1976's Avatar
11 Second Club
This is what I thought as soon as I saw the wheel well pic. My turbo/manifold is 3" away and I had to get a new plastic inner fender and put a piece of aluminum on it for a heat shield.
Old Dec 16, 2012 | 02:03 PM
  #50
Atomic's Avatar
Yea the fender is fine. I trimmed the plastic part where the wg sticks out.
