And they said it wouldnt fit....5" DP
Old Dec 15, 2012 | 01:39 PM
  #31
lglowe's Avatar
I added another jgs40 when I went with the Borg Warner on mine. Lets me go down to 8 psi with the 7 psi springs in each gate. Plus I think one more small one would be alot cheaper than a big 60mm
Old Dec 15, 2012 | 01:53 PM
  #32
Atomic's Avatar
I have a gauge for that
Have a jgs 50mm right now. I would do 2 but there isn't a good way to put a second one in there.
Old Dec 15, 2012 | 02:04 PM
  #33
lglowe's Avatar
Y off of that crossover. That should be easy
Old Dec 15, 2012 | 02:22 PM
  #34
Atomic's Avatar
And routing it back into the downpipe from the front of the engine is not so easy.
Old Dec 15, 2012 | 02:49 PM
  #35
stock48's Avatar
9 Second Truck Club
Originally Posted by Atomic
Well some results....I made a little dump pipe to a spare flange I bought to point the exhaust away from the transfercase. With the cutout not blocked off it is very loud and very deep and rattles every single panel of metal and plastic on the truck
Its also impossible to control boost. With the cutout open I cant give it more than half throttle without going 20+ psi with the wastegate fully open. I think I hit 26psi the first time I put the pedal down for a second, so thats no beuno. I blocked the cutout back and managed to keep it around 18psi with the 6psi spring and boost referenced to the bottom port of the gate. With the cutout blocked it has to flow through the 4" system.
At the same boost level, between the cutout being open and closed, its about a 200hp difference. So I would definitely say it helps
I am going to have to put on a bigger wastegate to try to control the boost at least down to 10psi or so.
Damn that's crazy! Makes me wonder if I need to upgrade my exhaust. I've always ran thru my full 3.5" from dp back exh and muffler lol.
Old Dec 15, 2012 | 02:54 PM
  #36
lglowe's Avatar
Ahh. Yea that would be a problem
Old Dec 15, 2012 | 02:58 PM
  #37
Atomic's Avatar
No you need to keep yours, you are already making everyone else look silly.
Old Dec 15, 2012 | 04:44 PM
  #38
stock48's Avatar
9 Second Truck Club
Naah just seems a little small to me, but the 3" core I/c prob keeps it from getting too much air anyway lol.
I wonder if those cutouts cause a turbulance in the pipe when closed. Being a flow minded person I have always wondered about that...
Old Dec 15, 2012 | 04:57 PM
  #39
Johnmaster's Avatar
MASS seller approved
Lots of time invested there, looks great!
Old Dec 15, 2012 | 05:54 PM
  #40
TrickTurbo's Avatar
Truck Sponsor
200hp difference?
Route 5" all the way back.
Installing a larger gate like a 66mm would require reworking the piping.
Might be easier to install a 2nd gate with its own muffler.
