Is there a direct replacement for PT88
Old Jul 24, 2013 | 08:48 AM
TrickTurbo's Avatar
Truck Sponsor
I would still recommend a hi mount.
The distance, that turbo size, and exhaust cooling is just no a solid combo if your hunting quick spool rate.
I regular 76mm magnum with down pipe correction would spool a lot faster. But then your loose your top end power if the bigger turbo.
It's a trade off. Down low from
a dig off idle or up hi.
Old Jul 24, 2013 | 09:48 AM
Simple converter swap might help issue..
Old Jul 24, 2013 | 02:13 PM
408superturbo's Avatar
Ya, right now I can foot brake it at the track to 2900-3100 but the rear tire will start to slowly spin at the line. If a small nitrous kit would make it come alive instantly at the track I will do that. Trick let me know, you can pm me what you can do for me as far as options and pricing thanks again
Old Jul 25, 2013 | 12:46 PM
Lutz's Avatar
If one were to go to the BW 480, what a/r size would be best for a rear mount? Higher or lower?
Old Jul 26, 2013 | 10:13 PM
shifty89's Avatar
The 87mm turbine may be a better fit for the 480 if you choose to go that route. The 83mm turbine is a lil undersized for the 8 bladed 80mm compressor. Maybe an s478 with the 6 blade compressor, much lighter than the 80mm.
Texas5.3_1251
Mar 5, 2016 08:10 PM
Superman09
Sep 25, 2015 05:55 AM
600 horses
Sep 10, 2015 11:01 AM
xerox17
Sep 5, 2015 01:23 PM
