Is there a direct replacement for PT88
I would still recommend a hi mount.
The distance, that turbo size, and exhaust cooling is just no a solid combo if your hunting quick spool rate.
I regular 76mm magnum with down pipe correction would spool a lot faster. But then your loose your top end power if the bigger turbo.
It's a trade off. Down low from
a dig off idle or up hi.
Ya, right now I can foot brake it at the track to 2900-3100 but the rear tire will start to slowly spin at the line. If a small nitrous kit would make it come alive instantly at the track I will do that. Trick let me know, you can pm me what you can do for me as far as options and pricing thanks again
The 87mm turbine may be a better fit for the 480 if you choose to go that route. The 83mm turbine is a lil undersized for the 8 bladed 80mm compressor. Maybe an s478 with the 6 blade compressor, much lighter than the 80mm.
Superman09
Sep 25, 2015 05:55 AM
