Theoretical Twincharging question
I'm not currently interested in attempting to twincharge a vehicle, but i've always been curious of the workings of it.
My question is regarding the blower compressing the boost from the turbo.
Would twincharging work w/ a roots or only a twin screw?
Let's say that the turbo is pushing 1.5 bar into the inlet of the supercharger: 1.What would the intake pressure be w/ a roots blower that pushes 1.5 bar when atmospheric pressure is supplied to the inlet?
2. What about the same for a twin screw?
Would a centrifugal supercharger be completely pointless in this application?
*I am only asking theoretically assuming that there would be no temperature increase or heatsoak and regardless of what engine it is applied to*
I would think the Roots (Radix) would be the one to go with just for its low end punch, then your turbos will kick in your mid-top ed punch...
Either way, you gots bigger ballz then me for even wanting to try this kind of setup... Props to ya...
There are some system's that use a smaller turbo spooling a larger turbo.
Also the sequential twin turbo's that use a small turbo for low rpm and a larger turbo for the higher RPM's.I plan to twin turbo my truck and want to do the sequential setup maybe.A turbo spooling a roots i have not heard of,though i have seen twin roots setups and also (8) turbo setup before.
Sounds interesting though I don't see a turbo spooling a roots,maybe a root's or centrifugal spooling a very large turbo.That would eliminate the low end power loss because there would be no lag,but in the end the cost would be the same as a larger roots compressor.The coolness factor would be the only reason i would do it.You would still have the parasitic loss of the roots on the crank.
Originally Posted by Yukon 400
Old school diesel truck engines use to have a turbo fed blower setup, I am not to sure about the specs. If it was done before i'm sure there is a way to get it to work on a gas engine.
Yeah, ive heard of the 2stroke twincharged detroit diesels. Those things are insane. I do realize that there would be parasitic loss from the blower still, but im asking this in a purely theoretical situation only regarding the boost that would be created by twincharging. On the cool factor, def. yes. My dream would be and ls7 w/ an mp122h side mounted on each side being fed by two separate turbos
but dreams and reality are completely different things.
Check this out . That should get some of you interested on figuring this idea out. That car is insane. Watch the videos.
