tb size and port work for FI applications
Old Nov 23, 2005 | 01:20 PM
Gmc²'s Avatar
Default tb size and port work for FI applications
what TB are you blown guys running, any 90mm's out there, i dont even know what the stock size is, im assuming 70mm, but im probly wrong,
port and polished tb's anyone?
any gains?
Old Nov 23, 2005 | 01:24 PM
TurboGibbs's Avatar
I still have the stocker on mine. I plan on going with an LS2 in the near future.
Old Nov 23, 2005 | 01:46 PM
Gmc²'s Avatar
sounds good what are the specs on an Ls2? are you going to switch the manifold out too?
just thought of something, do you mean a whole motor? or just the Ls2 tb?
Old Nov 23, 2005 | 02:03 PM
Fogle07's Avatar
i believe he means just the tb. i think the LS2 tb is 90mm. not 100% though. i know blownchevy is putting one on his truck. he has a thread in the gm section somehwere with pictures but it is for a electric tb.
Old Nov 23, 2005 | 02:04 PM
TurboGibbs's Avatar
LS2 throttle body. It's 90mm. It has a different bolt pattern. I have the radix so it mounts to the radix intake. I will make an adaper plate to do it. That is as far as I've gotten in my planning. I'm hoping Blownchevy or someone on here beats me to it and works all the bugs out before I have to.
The throttle body size can't be your boost problem, if that is what you are getting at.
Old Nov 23, 2005 | 02:06 PM
Fogle07's Avatar
https://www.performancetrucks.net/fo...hlight=90mm+tb
Old Nov 23, 2005 | 02:15 PM
Gmc²'s Avatar
no i know its not the problem im just looking into the future, just trying to learn what i can about FI
still trying to build a fast truck, while working out the kinks
71ls2
Jul 20, 2015 11:53 PM
bsn1989
Jul 16, 2015 08:20 AM
4B11T
Jul 13, 2015 03:48 PM
jrplz
Jul 9, 2015 12:07 AM
Gadgetized
Jul 7, 2015 04:40 PM
