tb get's stuck when meth is sprayed
Old Jan 24, 2007 | 09:52 PM
whoopassracer's Avatar
Default tb get's stuck when meth is sprayed and not sprayed
well ever since i installed the meth kit, while it sprays into the throttlebody it seems to get stuck, , cuz when i give it gas the gas peddle is hard untill i tap it harder so unstick then within minutes of driving normal without spraying it dont do it, i mean it doest it alittle bit not much as spraying. do any of you guys have this same problem as well, and im spraying washerfluid, thats all, or do i need to clean the tb good.
Old Jan 24, 2007 | 09:53 PM
dirt track racer 81's Avatar
do you have the throttle body bybass??..could be freezing..seriously doubt it ..if so hook the coolant lines back to the throttle body and see if thats the problem
Old Jan 24, 2007 | 09:55 PM
their not bypass,
Old Jan 24, 2007 | 09:56 PM
ColtSteele's Avatar
thats odd - i've heard of nitrous freezing the tb blades open but never meth. doesn't get that cold
Old Jan 24, 2007 | 09:57 PM
thats what i thought its weird to me that it does,
Old Jan 24, 2007 | 10:01 PM
TrickTurbo's Avatar
Truck Sponsor
Do you slam the throttle shut or just roll off the throttle? Have you tried without the meth spraying?
Old Jan 24, 2007 | 10:04 PM
well when i hammer it, i just take my foot off the peddle and when im not spraying it does it alittle bit, what can i do,
Old Jan 24, 2007 | 10:10 PM
slam it shut like just take my foot off the throttle quickly
Old Jan 25, 2007 | 06:04 AM
Wilde Racing's Avatar
How do I change this text
Don't worry about it. Why you tring to stop anyway? sheeesh...
I'd pull the throttle body off and give it a Really good cleaning...If that don't work REPLACE IT.
Old Jan 25, 2007 | 07:45 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
What Wilde Racing said. I cant see how one has much to do with the other. Sounds more like a mechanical issue.
