Target Lambda/AFR with E85
Old Feb 11, 2012 | 05:08 PM
Beatdown Z's Avatar
Laid Back
Default Target Lambda/AFR with E85
What Lambda/AFR are you E85 guys commanding in boost?
Old Feb 13, 2012 | 05:26 PM
marovetsm's Avatar
My stoich is 9.706 and PE eq ratio of 1.25 all across the board.
Old Feb 13, 2012 | 05:41 PM
scooter k's Avatar
.78 is what my wideband shows on Lambda
Old Feb 14, 2012 | 11:37 AM
Lextech's Avatar
After the stoich value of the fuel is entered into the tune as AFR, the PCM bases all of its fueling calculations on EQ ratio. It is best to think and tune in EQ. My E-85 boosted EQ ratio is 1.22
Jeff
Old Feb 14, 2012 | 12:21 PM
Atomic's Avatar
I have a gauge for that
lambda = 1/equivalence ratio
(for those that didnt know)
Old Feb 14, 2012 | 03:46 PM
Beatdown Z's Avatar
Laid Back
I've read multiple times that E85 likes a richer mixture, so I have my EQ ratio set at 1.31 or .76 lambda. Haven't had much time to play with it, but it feels pretty good.
Has anyone spent time on a dyno adjusting their EQ ratio up/down?
Old Feb 14, 2012 | 04:04 PM
ChevyTruck's Avatar
something else
Off Topic Question. Where are you getting your E85 at Justin?
Old Feb 14, 2012 | 04:36 PM
sharpshooter's Avatar
Only station in DE I know of is on 40 near Bear.
Old Feb 14, 2012 | 05:25 PM
ChevyTruck's Avatar
something else
I just wasn't sure if there is another station, he's close to the PA border.
Justin, I'd like to see that thing in action.
Old Feb 14, 2012 | 08:37 PM
Beatdown Z's Avatar
Laid Back
That's the one. Only about 13 miles from my house...
It's running right now, but still needs the intercooler hooked up. Hopefully next week I can drop it off at my friends shop so he can weld it up. Hoping to make some shakedown passes March 3 at Cecil.
