T6 turbo input
#132
yeap. i dunno maybe a thousand or 2.
3rd one in is the thrust bearing on these right? not sure if this goes back original shipping damage if they never tore it down to check. or when converter **** the bed if it ate it up then
so wtf ever, its out and back at thompson
#137
paranoia mostly, it started showing some random KR at idle i figured what just some big cam problems, zero while driving. it kicked the belt again so i went through the entire accessories for alignment, tilt, slack on the belt, the tensioner and idle pulleys. i was (an possible still am) real close to deleting everything but the alternator - switching it to a low mount with a real short belt. and going electric water pump, electric steering rack, back to vac booster or volvo hydroboost pump. pulled the balancer and noticed the thrust endplay was ridiculous.
#139
not really, engine still at tms. i had infinitely more fun just boosting the stock engine and pushing it till it blew, this shooting for x horsepower goal sucks
been putzing around a little bit, pulled the entire harness out of the engine bay; some of the loom i used before wasnt high temp i guess melted/flattened out i na few spots. going to lay it all out for the engine on the stand and tape and loom it up nicer, have a few things to shorten up.
still kicking around idea of going electric water pump and power steering- i grabbed a ford/volvo electric steering pump but its about the size of a 2 liter bottle, hard to find a good spot for it. will throw all the old accessories on it for now to make sure junk stays together for a while.
I have the np149 all ready to go in seems a little shorter than the bw4485, front shaft should work fine... the rear driveshaft i may need to get a longer one (back to stock length basically)
