Swapping pulleys on my Radix ???
Old Mar 4, 2008 | 12:26 PM
blue2003ls's Avatar
Default Swapping pulleys on my Radix ???
I think I want more boost. What can my stock 5.3 handle with pump gas? 91octane is about all that can be found around here. I currently have a 160 deg t-stat to install and two smaller pulleys, a 3.0 and 3.1. A new tune is a given but is there anything I should consider when swapping pulleys?
Old Mar 4, 2008 | 12:31 PM
brobradh77's Avatar
91 Octane..ouch that sucks IMO. Your running a 3.4 now so ya a tune is all i would worry about at the moment. I dont see that your running a cam or anything that would maybe suggest upgrading injectors.
Old Mar 4, 2008 | 01:06 PM
blue2003ls's Avatar
44lb injectors may not feed it? What would be next in line, 50lb injectors or is that pretty marginal as far as improvement?
Old Mar 4, 2008 | 01:07 PM
Last Call's Avatar
TOTM: January 2007
I ran a 3.1 with my old 5.3 and it was fine. It was about 9-9.5psi. I would start with a 3.25 or the 3.1 you have now and go from there.
Old Mar 4, 2008 | 01:11 PM
Last Call's Avatar
TOTM: January 2007
I think you will be okay with the 44# injectors with the 3.1 pulley. Your IDC may get up into the 90's though. I would buy a methanol kit before larger injectors. The meth will keep your intake charge cooler and add octane so you can run a smaller pulley without detonation. IMO
Old Mar 4, 2008 | 01:22 PM
blue2003ls's Avatar
I know I should have bought the Snow Methanol kit with it.
Old Mar 4, 2008 | 01:57 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I see you have the pulleys ready. I would also go down to the 3.1" and see how it is.
Old Mar 4, 2008 | 02:05 PM
BlownChevy's Avatar
blownerator
25 Year Member
3.1 will be about 10.6 psi
Old Mar 4, 2008 | 02:26 PM
trever1t's Avatar
You're such an optimist BC.
With excellent tuning these engines seem almost indestructable...knock on wood
Old Mar 4, 2008 | 03:32 PM
blue2003ls's Avatar
So would good tuning and meth solve this or do I need more?
Now you jinxed me.
