supercharger cooling system
Old Feb 5, 2014 | 09:18 PM
bajachevy37's Avatar
Default supercharger cooling system
[IMG] online photo storage[/IMG] this was originally how i i had the system routed and it worked fine. the only differnce from then to know is the heat exchanger. the other one was about the size of the stock radiator. the problem is i cant get this to pump the water now. any help would be appriciated thanks you
Old Feb 5, 2014 | 09:33 PM
and the reservoir is mounted up high. its the highest point on the sytem
Old Feb 5, 2014 | 09:43 PM
gamble686's Avatar
Is it the original pump?
Old Feb 5, 2014 | 11:28 PM
No it's about a year and half old. It's a Bosch. It turns on and pushes water just won't push it through this system now.
Old Feb 5, 2014 | 11:38 PM
TX Tahoe Z71's Avatar
My pump, same as yours, is mounted directly below the reservoir with the electrical connection coming out the bottom. Try flipping the pump over.
I've read this pump is good at pushing water, but not pulling it. Meaning it needs a constant supply of water from the reservoir. I am guessing your pump is trying to pull water and isn't able to very well the way the hoses are configured. With that pump, the water comes in from the top center and out the side. The feed side is flowing uphill.
Old Feb 6, 2014 | 03:58 AM
03sierraslt's Avatar
You have the pump setup to pull, it has to push.
Old Feb 6, 2014 | 11:34 AM
kbracing96's Avatar
Yeah, that is a centrifugal pump. It will not suck at all if it gets air in it and will not self prime. It needs to be at the lowest part of your cooling system so there is always water setting in it. If it gets any air in it, it will loose prime. That's why they put them under the coolant tanks.
Old Feb 6, 2014 | 11:45 AM
The pump doesn't have to be the lowest but you want it below the resevoir and as close to it as possible so it can then push the remainder of the system.
Old Feb 6, 2014 | 09:54 PM
Ok got it working. I moved the pump down so it was lower then the cooler and it started working. Thanks for the help.
Old Feb 7, 2014 | 04:23 AM
If the plumbing is the same it still isn't right.
